Export STL not working
Hi,
I have just updated to Sketchup 2015 and downloaded the Sketchup STL extension. However, when I try to “Export STL” it has a blank file extension and cannot save it as a STL. ???
I used to use Sketchup 2013 and had no problems previously.
Help!!!
Hm… the extension might need an update. But you should be able to export regardless - just manually append .stl to the filename.
Hmm… To me it looks the same in SU2013 and SU2015…
SU2013:
SU2015:
What is it that you see?
If you click Save, does it not generate a file for you? If not, what happends? (And is there any errors in the Ruby Console)
That’s exactly what i see!
I cannot manually add .stl to the box. If i save it as it is it saves it as a “file” not a Certificate Trust List that it was before?
As for the Ruby Console- a bit beyond me i’m afraid! What do io need to do?
Thank you for helping this muppet!
Sorry- I was really being a muppet!!! I CAN add .stl to the file name and it saves it as a Certificate Trust List.
Woohoo! I can 3d print again!
Thanks for the reply.
PERFECT :smiley: just the anwser i had been looking for the past 3 days …
this solution should be labled along with the expantion pack, sinc a rookie like me wouldn´t know what to do
but tanks a million
