Export single pages to DWG
I want to export specific pages of my 10-apge layout document to DWG. On the Trimble help page it tells me to check the box ‘export each page as a seperate file’, but this check box does not appear on my export menu (Layout 2025).
I can select a page range, but whatever pages I select, say 1,3,5 - the complete document is exported. Any ideas? Thank you!
It works fine in LayOut 2026.
The resulting exports from the current file.
Upgrade to SketchUp and LayOut 2026.
BTW, please update your forum profile. It shows you are still using SketchUp/LayOut 2021.
Thanks Dave - I’ve updated my profile as you suggested. I could upgrade to 2026 but I’d have to do Sketchup at the same time - as I’m importing into Twinmotion, I’m nervous about the knock on effect this will have. Is there any way of rendering out single pages in 2025, that you know of? Otherwise, I’ve realised I could replicate the layout file and delete the pages out that aren’t required for export. Answered my own question there!
You can have both SketchUp 2026 and SketchUp 2025 installed and switch back and forth. In fact you shouldn’t uninstall the previous version at least until you have everything set up in the new version.
Well, you could do that but it’s a process you don’t need to go through.
Yes of course, that’s a perfect solution - thank you! Much appreciated, Alice
