So, I have work for school and I need to export a model from online sketch up and it wont let me because when I click on export it just says nothing plz help
Have you saved your model first? If so you should then be able to go to the folder icon, then to ‘Export’ and choose a format. If you’re seeing something different than that post a screenshot to help.
Edit: also make sure you’ve logged in so you can save your model. You may need to disable pop-up blockers if you can’t get the login window to appear.
You could try with a different web browser and make sure there is no any plugin/extension that can block the correct behavior of the website.
