Hello, recently when I work on an old design and save it, then proceed to export and import into Twinmotion rendering 2023.2.4 it does not populate anything. It’s as if the file saving mechanism has become corrupted / parameters were modified that are no longer in a readable format. Old files that I have on the account export and import without any issues. Any ideas?
Test Model.skp (4.9 MB)
Attaching .skp file example that does not load when importing into Twinmotion.
hello,
it works just fine here with the file you sent
however as @mihai.s pointed out, 2023.2.4 is an old twinmotion version, you can update to 2024.1.2 which is the last stable version. there’s also the 2025.1 preview out there
thanks Paul, I tried the newer 2024 version and it does load; however, my 16GB RAM MACOS is not able to handle it so it is super slow. I’m not sure why it does open for you on the 2023 version and not me, I’ve tried re-installing it numerous times without luck.
I’m on windows, it may be a sufficient reason !
Perhaps @ateliernab can try on mac
I’m away from home (and my mac mini) for the next couple of weeks. All I have is my pc ![]()
