As Boris says there should be quotes around the name csv - so it’s 'csv' or "csv"
And if you use the 'correct ’ Ruby syntax and put parentheses around it, then never insert a space…
So e.g. it’s require('csv')
That’ just a mistyping. I’m using require ‘csv’ in the code. The problem is the same code works fine in SketchUp 2023 but doesn’t work in 2024. And when remove it from the code, the error report doesn’t appear.
But with the confirmation from @boris.beaulant, I’ll checked another session. Thank you all.
Do you actually have the file csv.rb [and its related subfolder] in this folder ? C:\Program Files\SketchUp\SketchUp 2024\Tools\RubyStdLib
Have you tried closing SketchUp, finding its installer’s exe file [in your Downloads], selecting its icon, right-clicking and ‘Run as administrator’… when prompted choose ‘Repair’.
Afterwards any missing files or awry permissions should get remade…
That’s a serious error. Something is definitely wrong.
The code string ().pos= isn’t contained in any csv related files. Also, I’m not familiar with ‘RbzTools’.
If you’re going to post error text in the forum, please post the complete text, as it’s impossible to guess what your problem is without it. You can change username, etc…
IIRC, Load Error::SyntaxError means that the file exists and was readable, but it contains a syntax error…
