Interestingly, I am having troubles with CSV.parse
require "csv"
=> true
string = "foo,0\nbar,1\nbaz,2\n"
=> "foo,0\nbar,1\nbaz,2\n"
CSV.parse(string)
Error: #<TypeError: no implicit conversion of nil into String>
=> nil
No extensions installed except the ones that come with SketchUp by default.
I am running SketchUp 24.0.553. Anyone else that runs into the same issues?
Weirdly enough, it seems to be related to starting SketchUp from CLI.
When I start SU as a regular user, I have no issues with the above written code snippet. However, when I start from command line, like the following:
cd /D "C:\Program Files\SketchUp\SketchUp 2024\"
SketchUp.exe -rdebug "ide port=7000"
That GitHub issue doesnāt apply here, it was about the optional col_sep: parameter.
Iām not aware of any significant issues with the csv gem. Iāve got code that updates https://msp-greg.github.io/, and it uses csv. Itās worked for several years.
I updated SketchUp moments after my post and am still experiencing the same issues.
I have no debugger attached.
I only have the issue when I launch SketchUp from CLI with the rdebug option. If I leave out the option, CSV functions as it should.
I have been launching SketchUp this way for the passed⦠9 to 10 years I think and have been using the CSV gem significantly longer in many extensions.
The class CSV::Parser is ācastā to an enumerator in Parser.parse() (parser.rb, line: 400). The error is raised on the first invocation of enummerator.next() in CSV.each() (csv.rb, line: 2693)
With the ruby debugger loaded I can replicate this failue in SU2017 and SU2024 with the following code.
class Bubble
def list(&block)
return to_enum(__method__) unless block_given?
yield 1
yield 2
end
end
bubble = Bubble.new
list_enumerator = bubble.list
#p list_enumerator.to_a
p list_enumerator.next
#=> #<TypeError: no implicit conversion of nil into String>
I think this is the fix. Let me know if further research is needed.
SURubyDebugger.dll is calling rb_convert_type() to convert a Qnil to a String using the method to_str(). But NilClass has no method named to_str(). Hereās the fix. Just drop this snippet of code into a ruby file and save that in the plugins directory.
class NilClass
def to_str(*args)
inspect(*args)
end
end
Update: The above Band-Aid fixed the example Iāve posted above but I see that it broke the CSV gem in a new and different way. oh-well.
I do not think this should serve as a permanent solution.
But only the String class should have a #to_str method, which is normally inherited as is and not overridden in subclasses. Its purpose is to return a new instance object of the superclass, when called upon subclass objects.
(And yes, the Fiddle::Pointer class violates this convention.)
What happens is that Ruby coders often use this convention as a rule, and do type checking with obj.respond_to?(:to_str) instead of obj.is_a?(String).
So, IMO, it is an issue of poor coding practice.
All other classes would have a #to_s method to do type conversion, which the NilClass already has.
Although your āpatchā may work in the short term, if this is fault of the SURubyDebugger code, then they need to fix it going forward.
Hereās what Iāve found. Although Iām familiar enough with the ruby tracepoint implementation I donāt feel confident in making changes to the debugger source code and will leave that to the pros
When the method next() is called on the Enumerator a c_call trace event is triggered in the SURubydebugger. This in turn makes a call to retrieve the current file path (rb_tracearg_path() in the code below). This results in the rb_tracearg_path() returning Qnil because weāre executing in two different Fibers/Stracks (see: ruby/vm_trace.c at master Ā· ruby/ruby Ā· GitHub). The subsequent call to GetRubyString() is where the error is raised. A check needs to be added to test for nil in the value returned from rb_tracearg_path().
@DanRathbun, unfortunately I donāt have access to 2FA for GitHub. If you would be kind enough to add that diagnostic information to the issue tracker It would be much appreciated.
