When “Import”, option is ‘as image’.
When click, ‘L’ or, ‘R’ etc. that message appears.
What problem?
What problem?
Please explain more clearly.
Import what ?
Click or press ?
Button or key ?
What problem ??
Currently you are not making a lot of sense !
The default Layer0 must always be the active Layer.
See this Help article … Does SketchUp Support Layers?
Thaks for reply.
When ‘Import’ image(jpg, bmp, etc.) and click ‘Line’ icon or ‘Rectangle’ icon, error message appears.
Layer0 is alive.
Thanks for reply.
I saw that page, but it was not helpful.
Do you place the imported-image, then ‘size’ it with the corner green-handles… and then try to activate another tool ?
If you press the [Select] before that last step, do you still get the message ?
Thanks for reply.
Ye, I did it. But problem is still. My SketchUp program is wrong?
Are you using the (my) extension “Layers Panel” ?
If so, you can deactivate this message in Layers Panel’s options.
Thanks for reply.
As you say, I did it.
Well, to deactivate is none related??
