Error inserting AutoCAD dxf file into layout 2025
Good afternoon to the Sketchup community, in layout there are several errors and they are listed below:
  1. The complete content is not inserted (figure 01)
  2. the polylines are distorted (figure 02), the correct thing should be as shown in figure 05 (autocad dxf)
  3. When using the expand action, then CTRL+Z does not work (Figure 03)
    In addition, I attach how the result is in layout 2022 (figure 04) which in my opinion is correct, I also attach a dxf file so you can do your tests
figure 01
figure 02
figure 03
figure 04: ok, SU 2022
figure 05: dxf
EG.dxf (387.7 KB)
Good afternoon, the problem is in LAYOUT 2025
I opened the dxf file, moved the model near the origin and saved it, and then in LayOut 2025 it was imported without problems.
But directly, it appears distorted in LO25.
@Colin
Thank you very much, greetings from afar, we hope that in the future there can be some improvement.
You’re welcome!
Most likely, now that you’ve brought this issue to attention, Colin will definitely notify the people who handle LayOut and they will fix it. I probably should have added @adam.
