Error in Extension Submit
I try to submit one of my extensions for review but got following error message…
“Error submitting extension
Dismiss”
There is no more explanation. Also this extension is similar to my other extensions. Can you help me to find the problem?
I highly appreciate you help in advance.
Have you follow this rules?
I know next to nothing about the extension review process (I’m not a SketchUp employee) nor do I know anything about your extension. However, that response seems lazy and useless! How is the submitter supposed to address issues when not even told what they are?
Sure. I published 11 extensions. Even this extension published before and I just upgrade it to new version.
The only method I know for developing extensions is to build them step by step, and then submit them for review to see if they meet the requirements. However, this process often frustrates and disappoints people in the SketchUp community. I wish I knew a more effective and streamlined approach.
Maybe I’m wrong, but I read this as if the submitting proces / uploading proces didn’t work. Not that it is reviewed and dismissed…
For solving this problem, I have to delete plugin completely and create a new one. I almost change everything in the old plugin but this problem never solved.
How did you solve this problem? I also encountered the same problem. Submit a new version of the plug-in prompt “Error submitting extension”
when I deleted plugin and recreate it, my problem solved. If it cannot help you, first use a plugin data file that worked before and check it if you have problem yet, change other files.
Thank you for your answer, I’ll try it
please let me know how you solve your problem.
I deleted the version that was not released successfully and recreated a version, but I still couldn’t submit it, prompting “Error submitting extension”
:joy:
