Error: callback function error dynamic components 1
I’m facing the error in SketchUp files, but when I save the same file on the desktop it works perfectly. I never went through that.
Screenshot_2
Is something in your file path named starting with a lowercase “u”?
No
Both a lower case u and lower case x as the first letter of a file or folder name will cause Dynamic Components to fail.
Deep down, the problem stems from the software’s interpretation of a string with the characters \u which indicate that a unicode charracter is intended, and \x which similarly indicates that a hexidecimal value follows.
So a string like "c:\Users\xxxx\myfile.skp’ is understood as c:\Users\x {errror, there are supposed to be digits here} xx\myfile.skp’
Thank u <3
I am getting this same error but i have none of these in my file path
"E:\Sketchup\Projects\Kitchen Round 2 Large Cabinets8.skp
This is the where the file is being saved
This is where sketchup is installed at
“E:\Sketchup”
Update:
I had “ in my material name. removing this worked
