Hi,
I hope someone could help me to find out what I am doing wrong.
I am trying to generate a report with the X and Y position of ALL components: even COPIES of components generated by the “copies” attribute in a dynamic component:
In SU18pro Reports I have those fields:
- Definition Name:
- unique object name.
- if I copy this object, there will be an additional line in the report (as expected).
- Description Name:
- optional description
- Instance Name
- the name of the object in the dynamic component’s attributes window.
So, I create a component --with a unique definition name–
I duplicate this component, and I get 2 instances.
And everithing seems fine in the Report.
But I miss the Entity Name:
- Entity name
- when I set the Copies attribute = 2, SU creates 2 copies with Entity names: XXXX copy 001 and XXXX copy 002
And those “sibling” objects are not in the report.
How can I solve it?
Am I missing something in the Report configuration?
Is there a plugin to make all components unique?
Thank you,
