Funny, but just yesterday I was struggling with a glass elevator not rendering right right. It came from 3DWH, so I clicked on monochrome mode, and sure enough it was full of reversed faces. After fixing them and making fully proper solids, it rendered as expected.
Iâve had a look at the model
The glass is made from a single face - so you need to enable the âthin wallâ option in the glass material - this will ensure v-ray knows what to do with it from either direction.
If you glass has thickness , then you can untick that
I didnât make this SketchUp model myself (I always check the faces), but indeed the glass was reversed.
I reversed the glass material and make a new 360 render.
I always use single glass, because sometimes it give weird reflections, but the box âThin wallâ I never saw before. Thank you! My computer is now rendering and it looks like the sphere is gone!
Glad that has worked.
If it was looking strange before , then it is probably related.
If you donât use the âthin wallâ option, then you need to make sure that your glass object is a solid object and the faces are facing outwards ![]()
Thanks for your help! Sometimes it is so simple to solve - and a lot I can solve - but you just have to know how to solve ![]()
Now, we noticed another âproblemâ⌠There should be big stones in the âinside gardenâ (I donât know the right word in English, sorry). In the SketchUp-model I can see them, so they are not hidden or so, but in the render the big stones are not visible ![]()
Itâs a rock that has come from Skatter - the file isnât linked to V-Ray, so you need to point it back at the original file
Ahhh ok⌠and how can I do that?
Go to the geometries area in v-ray and youâll find the file path - point it back to the model from Skatter.
I replaced the rocks with rocks from the 3D Warehouse, so this problem is solved too ![]()
@Elmtec-Adam @eric-s @Anssi @pyroluna @ateliernab @francisquitof I like to thank your for your great help, also in the name of my daughter in law! All problems are solved!
Thanks for reporting back. Good luck and donât forget to check, clean, purge, and organize those models from 3D Warehouse ![]()
For me it is normal to report back, so we can learn all and to thank.
This SketchUp model is not clean, organized etc. (this one is of my daughter in law). She uses SketchUp only for a year or 2 after I teached her ![]()
For myself: I work with SketchUp since 2006
and I know how to check, clean, purge, and organize for my own models and the models from 3D WH.
The models from 3D WH can surprise you indeed. Once (a very long time ago) I imported a glass bakery display. There were a lot of colored glasses in it, but you couldnât see it properly. The joke was that the person who uploaded the model to 3D WH changed the glass color only on one side of the face. When I started to render the SketchUp model some errors occurred.
Ericâs C-2PO SU protocol droid method. I like it.
