Eneroth No Padding Zoom
My 74th extension is out. It lets you zoom to entities with no padding around them, i.e. have the object completely cover the screen from one side to the other. This can be useful e.g. to set up precisely placed cameras when generating drawings.
https://extensions.sketchup.com/en/content/eneroth-no-padding-zoom
Hi there.!
This one prevents the dimension tool from working, at least in SU 2023.!
Sorry, my mistake, I’ve started SU with /DisableRubyAPI command, and the error is the same, I did a repair install and still the same - after you use the Text tool, all commands starts to loose focus, and you have to click on a different tray to regain focus, or click on a different toolbar…
This is SU 23…!
Have you tried updating to SketchUp 2025?
Thank you, but this will not happen. I use many extensions daily that are not compatible (one of them is Mc View Size, and a few others, like 2 extensions for PDF import).
And for many other extensions that I use that have been updated - I don’t know the reason because I’m not a programmer - but some developers used Ruby Encoder (rgloader) to make them compatible with SU24 and beyond, which causes so many problems inside Sketchup.
This is an issue that I started a post about in the Sketchup Forum.
