Just installed Eneroth Extruder to use, and for some reason the shape I am trying to extrude is stopping mid extrude. The Path I have chosen is a continuous edge, but it stops part way through.
Hi Michael, I think you misunderstand what upright extruder does. It prevents your profile from twisting like follow-me does when having more complicated paths…
On a straight line as a path it would do exactly the same as follow-me, and in this case you could also use push-pull.
Did you try to move the path and profile out of the drawing before extruding? It looks as if the extrusion is interacting with something hidden…
Just guessing here…
There’s a tiny little segment in your path right next to the profile. The profile is also not square to the first part of the path. I deleted about the first 500mm or so of the path and redrew that and I rotate the profile so it is perpendicular to the first segment. Follow Me worked fine then.
