Elevation height
Hi, does anyone know if there is a extension or some command that would give me the elevation height (z value) of on object in space. In autocad there is a command called ID which tells me the x,y,z coordintae of a point i pick in space. What I’m looking for is to pick the surfaces of my steel beams in space and to quickly make sure they are placed at the correct height.
Thank you
I think the Query tool in the Utility Tools extension does this, although I haven’t tried it myself.
https://extensions.sketchup.com/en/content/utilities-tools
Tools > Text
Thank you. I’ll look into it
Thank yiu for replying
Thank you fot your reply… i tried it and it worked
I use it all the time so have hotkeyed it to the " ? " key…
seems appropriate :slight_smile:
PS… I think TIG has a plugin to stamp Z heights on your model also
Thank you for sharing the video. I think TIG has a plugin to stamp Z heights on your model also
Thank you,
Amol Patel
https://healthhakim.com
Some of my oldies…
