Dynamic Components - Report
Good afternoon, I’m having problems extracting a report from the dynamic components created.
As in the attached image, it can be seen that the vertical components have a different length from the horizontal components, but in the report they are coming out with the same dimension, is there any way to fetch this information correctly, how can I solve this problem?
DC-Report.skp (137.4 KB)
the “generate report” does not handle DC copies changes whereas OCL does
you have to add another sub-component, one for plates, the other for studs if you wish to use the report
this gets complicated for raked frames, so I recommend OCL until this reported “bug” is fixed, going by the SAD track record, DCs are not receiving any fixes
