Dynamic components | multiple movements with one click
Hi. I can use some help. I want to create two animation actions with one click.
The table (parent) has to move in vertical postion. From 0 to 500mm. The leg (child) has to rotate. When the table is at 0 then the leg has to be horizontal. When the table goes to 500 the leg has to be rotating to an end position of 90 degrees around its X-as. Both the movements in an animation for 5 seconds. See the attached file.
If someone can help me out. Thanks a lot in advance.
Regards, Sander
Table multiple dynamic components.skp (193.5 KB)
Table multiple dynamic components.skp (142.9 KB)
Thank you a lot, that was what I was looking for.
One addition. I want to be the leg in the horizontal position before the end of the vertical movement of the table. E.g. at a height of 200mm. Is that possible as well to animate?
Regards, Sander
Table multiple dynamic components (1).skp (148.6 KB)
