I’m looking for the earliest reference I can find for the dxf format. I found the ones for Release 14 from AutoCAD at this link, but I was hoping someone might have one from an even earlier version. Thanks.
I was not able to run the R13 EXE from the same link - does anyone know how to open it? It’s probably a DOS executable.
Actually 7zip was able to extract the .hlp file from the ,.exe but now I don’t know how to open the .hlp file. WIndows 10 does not support it. I’ve been looking through old Windows CD’s for WINHLP.EXE but have not found one that will run on Win 10.
I happen to have an XP I use for work, so it was easy enough to extract and run it. You mention Windows 10, but if you have access to a Windows 7 machine, you might try this approach:
In DOS AutoCad (v. 2.5 …13) the help was in a printed manual. Unfortunately they were too heavy to carry around when my workplace has moved several times since then.
