DWG Import Advice
A quick question please.
Is it possible to import the attached DWG file into SketchUp without these leader lines appearing?
The image below shows what I currently get, and I just wonder if there’s a way to lose those lines without exploding the component and deleting them manually each time?
Thanks, :+1:
75DI-0125.dwg (181.6 KB)
Perhaps AI could write code that tracks that tag name and deletes it (including the geometry) immediately after you import the file.
Point taken :rofl:
Thank you.
or could AI write an extension that would import the missing text in vector format ?
Or you could just import the text in vector format with the native importer (in SU2027).
Now that the importer has been updated to support most AutoCad annotations, it would perhaps be a good FR to ask for a “Features to import” dialog to let users select what object or annotation types to leave out. Previous versions of the importer only imported “geometry”.
