DWG exporter
The DWG exporter does not work right in Sketchup Pro for Mac(not sure these problems exist for PC). I am required to set it to Autocad version 12 to eliminate the NLS warnings I get in Autocad but in version 12 I keep getting invalid DWGS. I xref the DWGs from Sketchup and I keep opening drawings with missing invalid drawings. I have to open the drawings and then set all layers to zero, because with section fill it forces layer names so I need to get rid of that, and save to fix the invalid problem. Please get an export version of DWGs to work right. This problem has existed for YEARS (at least 4 that I know of). I have tried to use layout but it just is not ready in my opinion to do full construction documents. I use the Sketchup model as the master for plans and elevations so I end up with around 10 refs for each project…This is super time consuming when making changes.
Please fix this or if someone has found work arounds please help!
Thanks,
Russell
What version of SketchUp are you using? Please complete your forum profile.
Sketchup Pro 2020 version 20.2.171 and Autocad for Mac version 2020. Updated Profile
