I’m trying to re-create the central part of an axial bearing.
I wanted to use the rotate tool to the duplicate the initial hole and set the angle at 32.7272 (i.e. 360 ÷ 11) , and then enter x10. Unfortunately I still had to do ‘intersect faces with model’ and click on each duplication twice, to get the hole to appear…
Also you could select the top surface (minus the holes) and then"shift-select" the complete top face which will select all the holes and then delete them all at once. - repeat for the other side.
One thing you can do rather than doing 22.7272 is
Start the array, type 360 and hit enter then type 11/ enter and you’ll have 11 spaced perfectly around your ring.
