Hello,
I am drawing a jar and I need a smooth recess in its bottom. On another jar I drew sometime ago (different size) I made a smooth recess on the bottom as you can see in this picture:
This is exactly what I’m after but with the new drawing I can’t get a smooth recess like that. I start with a flat bottom:
Offset tool, 5mm:
Again offset tool, 3mm:
Now if I Move the inner circle on the blue axis 1mm down I get:
Which creates an array of small rectangles and the recess is not smooth at all.
Why can’t I push the inner circle to create a 1mm smooth recess?
Thank you!
