is there a way to draw a curve on a particular plane?
Um… yes
Perhaps you could explain a bit more what you need to do.
I am drawing a tram platform roof with the shape across done but I need to draw the longitudinal shape,
Hi
Assuming the profile is the same for the length of the building, maybe create a face with the shape shown, Push/Pull it to the desired length, then delete the bottom face, leaving an arched profile.
Could then use Joint Push Pull to give it some thickness.
Mike
There’s various methods including extensions. A simple method would be push pulling the original shape to the desired length, then scaling the end horizontally and vertically to form the taper. The attached image shows what I mean.
Or you could use either the Arc tool, or a Bezier Curve extension, to draw the longitudinal profile, then use Fredo6 Curviloft extension to fill in the surface.
