Hello,
Creating a small script
I want to display the back side draw line dotted when @model.rendering_options[“DrawBackEdges”] is on.
thanks
see attach image
require 'sketchup.rb'
module BoundingBoxViewer
class BoundingBoxTool
def initialize
@model = Sketchup.active_model
@selection = @model.selection
@bounding_boxes = []
@hovered_point = nil
update_selection
@ip = Sketchup::InputPoint.new
end
def activate
@model.active_view.invalidate
end
def update_selection
@bounding_boxes.clear
@selection.each do |entity|
if entity.is_a?(Sketchup::Group) || entity.is_a?(Sketchup::ComponentInstance)
bbox = entity.bounds
points = get_bounding_points(bbox)
@bounding_boxes << points
end
end
end
def get_bounding_points(bbox)
corners = (0..7).map { |i| bbox.corner(i) }
def midpoint(pt1, pt2)
Geom::Point3d.new((pt1.x + pt2.x) / 2.0, (pt1.y + pt2.y) / 2.0, (pt1.z + pt2.z) / 2.0)
end
middle_z = (bbox.min.z + bbox.max.z) / 2.0
def plane_points_at_height(bbox, z_height)
p1 = Geom::Point3d.new(bbox.min.x, bbox.min.y, z_height)
p2 = Geom::Point3d.new(bbox.max.x, bbox.min.y, z_height)
p3 = Geom::Point3d.new(bbox.max.x, bbox.max.y, z_height)
p4 = Geom::Point3d.new(bbox.min.x, bbox.max.y, z_height)
p1, p2, p3, p4,
midpoint(p1, p2),
midpoint(p2, p3),
midpoint(p3, p4),
midpoint(p4, p1),
midpoint(midpoint(p1, p3), midpoint(p2, p4))
end
bottom_points = plane_points_at_height(bbox, bbox.min.z)
middle_points = plane_points_at_height(bbox, middle_z)
top_points = plane_points_at_height(bbox, bbox.max.z)
bottom_points + middle_points + top_points
end
def draw(view)
return if @bounding_boxes.empty?
view.drawing_color = "red"
@bounding_boxes.each_with_index do |points, index|
points.each_with_index do |pt, i|
special_purple_points = [5,6,7,8,14,15,16,17,23,24,25,26]
point_color = if (i + 1) == 18
"red"
elsif special_purple_points.include?(i + 1)
"purple"
else
"LawnGreen"
end
view.draw_points([pt], 8, 1, "Gray" )
view.draw_points([pt], 6, 2, point_color)
screen_pt = view.screen_coords(pt)
text_color = (i + 1 == 18) ? "red" : "black"
view.draw_text([screen_pt.x + 5, screen_pt.y - 5], "#{i + 1}", size: 12, color: text_color)
end
dotted_line_pairs = [[10,11], [11,12], [12,13], [13,10]]
view.drawing_color = "black"
view.line_stipple = " - "
dotted_line_pairs.each do |pair|
p1, p2 = points[pair[0] - 1], points[pair[1] - 1]
view.draw(GL_LINES, p1, p2) if p1 && p2
end
if @model.rendering_options["DrawBackEdges"] == true
view.line_width = 1
end
end
end
if @hovered_point
view.drawing_color = "blue"
view.draw_points([@hovered_point], 10, 1, "Gray")
view.draw_points([@hovered_point], 8, 2, "Red")
else
@ip.draw(view) if @ip.valid?
end
view.invalidate
end
def onMouseMove(flags, x, y, view)
best_distance = 10
@ip.pick(view, x, y)
@bounding_boxes.each do |points|
points.each do |pt|
distance = Geom::Point3d.new(screen_pt).distance([x, y])
if distance < best_distance
@hovered_point = pt
best_distance = distance
end
end
end
if @hovered_point
Sketchup.status_text = "Hovered Point: #{@hovered_point}"
else
Sketchup.status_text = ""
end
view.invalidate
end
end
def self.run
Sketchup.active_model.select_tool(BoundingBoxTool.new)
end
end
# REMOVE "#" TO ACTIVATE TOOL DIRECT
BoundingBoxViewer.run
