DRAPE TOOL - not draping
Hi.
It’s been a while since I last used the drape tool. I’ve searched on Google and YouTube and poked around the forum here without anything that seems to match what I’m experiencing.
The default face in the foreground needs to drape onto the textured form in the background. I select the default face, then select the drape tool and thereafter the textured form in the background. I’ve reversing this selection process as well without success either. Gosh, what am I missing?
Drape.skp (1.5 MB)
hello
drape tool has to be used on blue axe, meaning the object (or edges) you want to drape has to be above the surface you want it to drape it onto, it can’t be used from side to side
in your case, just push pull your face and intersect it with the other object
intersect
Of course!!! This is a good example of when pressure stops one from thinking clearly. Thank you so much.
