Hi everybody,
I’m struggling around the way to drape an image (orthoimage) over a model made importing data form a .dem. file.
I’ve tried following a couple of tutorials which suggest to make a flat layer above the model, fill it with the image as a texture and then project the image, but it doesn’t work for me.
When I import the .dem file, obtained form Lidar data and exported form Surfer as a . DEM file, the model looks fine, but with all the face of the polygon, thus I create a unique surface, then I place above it a flat layer and fill it with the texture of an orthoimage. Now, I could I drape it over the below model?
- explode your image
- right-click on image > Texture > Projected checked
- then follow the steps in this GIF
Thank you mihai.s. When I use the bucket it only colors all the faces of my model like this:
Any suggestion? Thanks
- right-click on image > Texture > Projected checked like in GIF.
Texture must be “Projected”.
Thanks, I did it again, and now it worked!
The quality is very bad of the sandbox derived from the .dem file even if it’s taked from a High resolution survey (Lidar 2x2m). Any suggestion on how to improve it?
Thanks.
I have not worked with .DEM files so far, but for 3D models of a terrain, I would use Fredo6 TopoShaper.
Also see if the tips here are useful to you: Importing DEM Files for Terrain | SketchUp Help
