Downloaded some rb files but they will not show up in my Extensions manager
downloaded some rb files but they will not show up in my Extensions manager
RB files won’t show there. Have you copied them to the right place? For RBZ files, use the Install Extension button.
Simply downloading them won’t install them. If they are .rb files you’ll need to first pack each one in a zip file and rename to .rbz before using Install Extension in the Extension Manager.
What .rb files did you download and from where?
downloade d progressbar, wndowizer from Smustard website
So do as I told you in my previous post.
Both of these are old .RB scripts.
They will probably still work, BUT you’ll need to ‘install’ them properly to see if they work…
There are several, way so do this…
Open your Plugins folder [relating to your specific SketchUp version] and add the RB file to it, then restart SketchUp to load it…
…Or if you have a newer SketchUp version - in Windows, select the RB file and add it to a new ZIP archive, then rename that file from .ZIP to .RBZ
Then use the native installer within your SketchUp version to ‘install’ the contents of that .RBZ file…
