I am trying to download stl file so I can send it to someone that has a 3d printer, it downloads an certificate error
What can I do? How can I make use of the SketchUp?!?
I am using online SketchUp
I can download my file as an png, as am skt but when I try as stl is give me this error:
" Invalid Public Security Object file"
“This file is invalid for use as the following: Certificate Trust List”
From my understanding of that error message, it is Windows (not your browser) that is set to only allow downloads from trusted sources. I am on a Mac, so I cannot dig in deeper, but perhaps someone whow is Microsoft savvy will swing by and give you an idea of how to tell your computer that it is OK to download a file from Sketchup Free.
I can, but I just wanted to check… Are you hoping to 3D print this? It is not a solid, so it won’t be printable… In fact, it is several nested groups that lap over each other. If you are hoping to make it printable, then you will need to work on it a little more so that all the geometry is in the same contenxt, and the Entity info, when the group/componentn is selected reads “Solid”
Thank you both. I will work some more on it, it is my first time I try to do something like this, I have no special skills so I hope I can just learn from experiencing.
Thanks again.
No problem, make sure to go through the videos on the SketchUp you tube channel. Watch the beginners series and you will be flying in no time.
Also try to use some real life hooks for reference (if indeed that’s what you need). It will give you some pointers about how they are put together and also how you may attach them to a surface so they are stable.
