Dimensions suffix for Scale tool not working on Mac OS Ventura in French
If I type mm, cm or m after a number it works.
If I use ’ for feet or " for inches, it doesn’t work.
Is this a bug ?
I would say so, as it works fine in English on Windows.
It may be the regional settings causing the issue. Like having to use ; instead of ,
Or “smart quotes”?
Smart quotes are off on my Mac.
SU 2022 on my work PC (Windows) works correctly with the Scale Tool.
I have another problem on the PC but I prefer to start a new thread to avoid mixing things too much.
I tried setting my region to France, and my keyboard to AZERTY. With that I could scale to 10 inches with shift-&, Shift-à, " (the 3 key). I could scale to 10 feet with shift-&, Shift-à; ’ (the 4 key). Is my test valid?
What I find strange and illogical is that I can use the ’ for feet and the " for inches when specifying a length for an edge, a radius for a circle, a displacement value or whatever length I need to enter.
It is only when specifying a length with Scale Tool that it doesn’t work, As soon as I type the ’ or the " the VCB field get emptied and filled with only the ’ or the " and, of course, if I press the Return or the Enter key, I get an error.
I’m not near a computer to check, but is this related to how shift affects the scale tool. Perhaps you need to click to finish the scale before typing anything that needs shift.
I don’t use the Shift key. It is just a simple scale along only one direction.
I can use mm, cm and m as a suffix but not ’ and ".
ok, I tried, made a 1m cube, grab the tape mesurer, turn guidelines off, hopbidiboup, ask for 1" - it scales
then, undo, select the cube, take the scale tool, scale it down randomly and ask for 1" - it scales too.
then, same thing, but I type the 1" after randomly scaling, still works.
not sure where if fails on your side… I’m using the lastest ventura and SU releases. in french.
Fair enough, my mistake, I just know with a qwerty you need shift to type "
I got it to work using this workaround:
1 - Select object;
2 - Select the Scale tool;
3 - Scale using a pure number as a scale factor;
4 - Type a number followed by a unit suffix like ’ and " followed by a press of the Enter key.
Now, the suffix is appended to the number instead of clearing the VCB.
I still wonder why using mm, cm and m works and using ’ or " doesn’t when used immediately after scaling but before pressing the Enter key.
