When working in a component, and not a complicated one, I’ll arrange the dimensions so they’re visible in 2D but when I close the component they move. When I open the component again, they return to the configuration I set them to. I’ve looked through the options and don’t find anything related. I’ve restarted the software and the computer. Suggestions are appreciated!
You scaled the components on the right without opening them for editing. That means their definition is different than what is displayed. Noticed the Scale Definition is not available when you right click on a component on the left but it is on the component on the right.
If you fix the component on the right by clicking on Scale Definition, the dimensions won’t move anymore. You will need to update their positions since you added the dimensions before correcting the definition.
If you scale components like that you should always remember to scale their definition.
I’m curious. Why not do your dimensioning in LayOut. You could make a much more prefessional looking job of it.
Are the ends of those pieces supposed to be smooth curves or facets as you’ve drawn them?
I’m self-taught and kicking the can down the development road until we can hire a designer that knows what they’re doing. Fortunately our machinist is a patient man. These parts are for water jet, it’s the second iteration and smooth curves are implied. I’ve attempted to smooth them in the past and made a mess of it so I’ve opted to leave them as you see them.
You don’t just open the .skp file in LayOut. Either in SketchUp go to File>Send to LayOut or in LayOut go to File>Insert and select the SketchUp file.
You need to create scenes in SketchUp to show the model as you want it in the views in the document. Here’s an example of a thing I did a little while back. It’s not really intended to be a complete shop drawing but should give you an idea. Each view of the model from a separate scene in the SketchUp file. For the plan, elevation, and section view the Camera was set to Parallel Projection in SU before creating the scene.
You might want to spend some time going through the instructional materials at learn.sketchup.com
