Where can I change the default setting of Dimensions?
I always want i aligned to the matter and centered.
it’s in your menus, window / model info / dimensions.
once you change something here you can apply it to all the new ones but it will also be the default setting for all the new ones.
Thankyou, perfect.
hello,
if you want those dimensions settings to be remembered for your upcoming models, remember that you can save a template once they are set up, so you don’t have to do it over and over again
Thankyou for adding that, I do need to make a template with all my choices. I just keep rushing into drawing assignments with too little time to get the basics fixed
