Developer Extensions & High DPI Displays
I have searched the web and this forum in particular but have found no recent guides for developers to address the high DPI issue. I can provide larger pixel icons, but the WebDialog and their text don’t scale either. Is there a way to instruct SketchUp to scale dialog boxes in Ruby?
Joe…
setting the fonts in mm using css should be the same for all screen factors…
does this render correctly on a high DPI monitor?
you should be able to measure it with a ruler…
html = %Q[<!DOCTYPE html>
<html>
<head>
<style>
body {font:caption;}
h1 {font-size: 15mm;background-color:pink;}
h2 {font-size: 10mm;background-color:lightblue;}
p {background-color:lightgreen;
font-size: 5mm;
line-height: 10mm;
</style>
</head>
<body>
<h1> font-size is 15mm</h1>
<h2> font-size is 10mm</h2>
<p> font-size is 5mm, line-height is 10mm</p>
</body>
</html>
wd = UI::WebDialog.new("mm", true, '', 700, 300, 200, 200, true )
wd.set_html(html)
wd.show
john
Hi John,
Thanks very much for the reply and the test code. Here is what I measured on my 1920 px x 1200 px display, which measures 20.5" x 12.75".
Lines:
Pink - 20mm
Light Blue - 14mm
Light Green - 10mm
Text:
15mm - 11mm measured
10mm - 7mm measured
5mm - 4mm measured
I don’t have a high DPI monitor, but the user of my plugin, who brought this issue to me, does and I am going to have him run this test. I asked him to upgrade from SketchUp Make 2016 to SketchUp Make 2017 and the dialog boxes are now scaling. But my extension icons are still very small; they apparently don’t scale. Do you know a way to specify vector artwork for the icons in a Ruby extension?
Thanks again for your help.
Joe…
to handle all three options I just use…
    # to handle the new file formats for toolbar images...
    ext = '.png'
    ver = Sketchup.version.to_i
    if ver >= 16
      osx = Sketchup.platform == :platform_osx
      ext = osx ? '.pdf' : '.svg'
    end
    cmd.large_icon = cmd.small_icon = File.join(path, 'Resources', 'images', "#{NAME}#{ext}")
my images are all large [512 x 512] and I let SU deal with the scale…
john
Thanks John. I am going to give that a try.
Joe…
John, that worked perfectly. Thanks again.
Joe…
