Hi, I need help with my spiral stair stringers. The treads & risers are fine (made from a 2D Cad file) but when I use the follow me tool, the blue axis of the face bends off vertical. Going a bit crazy!!!
Without at least an image [but preferably a SKP] we would all have to guess !
FollowMe is known to ‘twist’ its results.
There are Plugins to avoid this [search].
However, if you stair is a perfect helix [the proper name for a spiral-stair] then you can simply make a component of one tread/string/handrail, and then use Rotate+Ctrl to make a copy and NNx to replicate that…
Then individually Move those copies up in their Z to the desired heights…
Sorry How do you to attach the .skp file?
In you post - OR just drag-n-drop the file onto the post’s pane…
Mr. TIG
Thanks got the plug in. That should do it.
