Default Materials deleted accidentally in Folder Glass and Mirrors
Dear all,
I accidentally deleted the default materials in the folder Glass and Mirrors. I cannot just reinstall Sketchup because I have not admin rights on my company PC and working from home makes it even more difficult.
My folder is empty now
C:\ProgramData\SketchUp\SketchUp 2020\SketchUp\Materials\Glass and Mirrors
the other folders e.g. contain the materials like Asphalt New.skm
Can I download and copy the sketchup default materials back in the folder? I can imagine this would be the easiest solution?
Thanks in advance,
Marcel
Here are the materials in a zip file. Extract them into the folder.
Glass and Mirrors.zip (114.7 KB)
Hi Dave,
thanks a lot for the material files. It works just perfect. Is there a source on the sketchup webpage where I can find dose files in case I accidentally delete more materials from the default materials?
I assume you copied the files from your installation?
Have a great day.
Marcel
I don’t think the OEM materials are available separately. You’d normally have to reinstall SketchUp to restore those files.
I did copy them from my installation.
Thanks for your support.
Hi Sketchup Team,
can you not make the default materials of Sketchup available as separate files? Just as an idea.
Thanks for taking note.
MArcel
Not to say it wouldn’t happen but yours is the first request for this that I’ve ever seen in more than 17 years of using SketchUp.
Hi- I know this post is outdated, but hopefully I can still get help. I actually did the same thing with a glass texture. I downloaded this file, and can’t figure out anyway to extract them. When I double click on them nothing happens. When I try and open them up as SketchUp files, nothing happens. Is there anything you can do to help? Thanks!
Hey,
I have the same issue here. Would you be kind and copy most of yours materials and share them here? Thanks
Sorry. I don’t share my custom materials.
The native ones you should be able to get from the 3D Warehouse. Or you can copy them from an older version of SketchUp.
