DBS - Move Rotate Open Close ( free extension )
Hi,
Check my free SketchUp extension.
It allows moving elements in a defined way.
You can use it to open & close kitchen cabinets/drawers with one click or…
for any other sliding or rotating movement.
Find it:
:point_right: SketchUp Extension Move Rotate Open Close
Let me know your thoughts below.
Hi,
I’m working on an update for this extension. Please check the below video with some play during testing.
You can see there also how to download it.
Do you have any specific needs or ideas for that plugin?
Let me know. I may add some of those.
I added a new version of this extension on my site.
v3.8
It’s FREE and you can find it here:
Hello. I am using V3.8. Usually I can figure out how to use it. Is there a detailed instruction manual on how to configure or in my current situation how to clear a configuration. I have added a hinge joint to an object which I need to remove and place on a different edge. Thankyou.
Hi,
Check the below video describing how to use and configure this extension.
A new version released. :rocket:
v3.9
changes:
  • fix the issue with the Image object in the model
  • Main menu moved to Extensions → DBS
To download :point_down:
:link:
SketchUp Move Rotate Open Close
New version released
v4.0
