Hi there
I am a complete beginner and have modelled this form which will be made out of 12mm particle board.
Each of the faces has been saved as a Component, with the exception of the largest piece which is a group.
Particle Board Form.skp (127.2 KB)
My aim is:-
- To take the bottom edge off all the groups so they are level with the Guide line which runs along the bottom of the internal vertical support piece.
- To remove the excess off each component where they join so that I can measure the angles of all the different pieces
where they join.
I have looked at the Tutorial on creating angles Using Sketchup to Create an Angular Mini Shelf - YouTube but in my model the components have converging lines. All help would be greatly appreciated!!
