Hello. Im trying to draw curved glass around the stairs by using Curviloft. For whatever reason my plugin buttons are missing:
It doesn’t matter whether I use it on something simple as two circles or something else. Roby console shows me this:
LAUNCHER TEM 9174127689.677956
Error: #<NameError: undefined local variable or method accept_current_selection' for #<Traductor::EdgePicker:0x000001fc08d3e900> Did you mean? validate_current_selection> c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:397:in analyze_initial_selection’
c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:388:in check_initial_selection' c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:332:in activate’
c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft’
c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:53:in action__mapping' c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in call’
c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in launch_action' c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action’
c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:91:in block in startup’
c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke' c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands’
c:/users/kmyl/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command’
I updated both FredoLib6 and SUStore. Any ideas what could be the problem? Thanks!
