Curved surface
Hi, I have a stonewall component that I’d like to put on a curved landscape - so that the stonewall follows the curves.
You could use Drape, Fredo JPP, Follow Me, Flowify, etc… it can be done in many ways, depending on what the terrain and wall look like and what tools you know how to use in SketchUp.
an idea
Click in sequence on the scenes tabs of this SU file for ideas. No need for plugins.
Road on topo.skp (1.1 MB)
Thanks. Flowify seems complicated. lol. The video is great is I use a texture to paint the wall. But, I have a wall component that I’d like to use. It’s many stones built together.
Like I said… it depends on what the terrain and the wall look like. You’re the only one who knows what those look like.
Yes indeed I am. The wall component is made up of several loose boulders, so there is no face or surface.
OK, you should have stated that in your first post. My example is for a road or a wall made of continuous faces.
Maybe you can paint it with an appropriate texture but, if you really want discrete stones, my trick won’t work.
hello,
you can use path copy or equivalent
@paperbark.co you should post the file or at least post some screen shots of what you are trying to do.
Reading minds is not the best way to get your problem solved.
I knew you were going to say that.
