Curve railing / fill curve/not flat surface
hi,
anybody can show me or teach me how to create curve solid railing or how to fill curve/not flat surface?
thank you
Delete the faces inside of the wall just the faces not the lines, draw diagonal lines, right click on one of the white faces, and select orient faces.
sorry cant understand..draw diagonal line at which surface?
You can share the file by dragging it into a comment.
Draw them at where you are not getting them.
For a face to be created the corners (endpoints of the edges) all have to be on the same plane. Yours aren’t so you need to draw a diagonal to create 2 triangles.
(to illustrate his message)
There are a lot of ways to model what you are after. One cleaner way than what you have modeled would be to extrude the railing up to the lower height and then use Curvishear, which is included with FredoTools (from Sketchucation) to create the sloped curves. Extrude the rail up to the top height, erase what you don’t want and then finish the top by stitching between vertices or more quickly using Curviloft, also from Sketchucation.
With Curviloft you won’t wind up with the reversed and internal faces as you have now.
