Hi everyone, I just released a new plugin for SketchUp to help control the camera in a narrow view.
I created it when modeling the ceiling with a bad experience when the camera was constantly being obscured by walls and furnitures.
Hope you like it!
Version: 1.0.0
SketchUp Compatibility: SketchUp 2016+
Get the extension here
I made a wall with âMAJ Wall Makerâ extension but it seems your extension cannot work for this wall. Would you please check it and let me know the problem?
I installed this extension and it seems to work fine on a very simple model (just a straightforward box).
However, on a more complex model, where it would be much more useful, it seems to have no noticeable effect. I have tried changing the distance it works at, but neither lengthening nor shortening makes it work.
I donât produces âboxesâ - I model existing residential properties and work on extending and altering them and the plugin seems to work ok for me so far
Many thanks for your reply â I really appreciate your offer to help.
Itâs a very big file (20+ MB) and although Iâve tried to reduce it, I canât seem to get it below 11 MB. Iâve removed a number of entities from the Warehouse that I thought might be increasing the size, and that tool out 9 MB, and Iâve purged the file too. Maybe something underlying that is the problem with the Zoom through extension?
Bit late in the day i know, but? I had this problem for a while, We all know SU has its problems, fantastic program, but a program none the less, and sometimes tend to get a bit cluttered in the memory department, throw in another program extension and its bound to cause a few issues, The simplest way I have found is to make sure all Tags are open, then select all Ctrl C, open a clean SU program, Ctrl V, this brings in everything into a clean uncluttered program, works every time and easy, do not save as a copy doesnât work, only takes a few moments
