Crosshatch Fill Patterns
I am doing a simple cross section of component made up of several sub components. I cannot find simple engineering drawing cross-section fill patterns to distinguish one sub-component from another. I can see “Patterns” under “Materials” but they seem to be scaled for much larger objects in section - for instance, the checkerboard pattern only produces black if I use it in a subcomponent. I can use colours, I guess, in lieu of cross hatch patterns, but would still like to know if they exist within Sketchup Shop.
Thanks.
Doug
You could import a suitable image and apply it to the face as a texture.
Dave R,
I designed a simple pattern in CorelDraw.
How does one make it seamless?
How does one apply it to the face as a texture?
Water Pattern.skp (2.5 MB)
Thanking you in advance.
DJH
You ought to be able to make it seamless in Corel Draw or in an image editor. Do a Google search for that for Draw. I expect you’ll get a bunch of tutorials.
You should make it match as a ‘tile’ in corel. The sides and top and bottom should be ‘the same’ or the matching half.
Here I have done it within sketchup.
You can see using your image as a material the ends can’t meet because of the way you have created it.
But if I cut off the edges at a matching point it flows through without the obvious transition.
Seamless
Box, thank you very much.
If you want to use the patterns, you can adjust the scale of any texture by using the context menu.
