Last week I’ve been asked how to create Hatch Pattern Textures to use with Sketchup Sections. Here it is:
- Create a very big flat square component with the corner in the origin of the model axis. Mine is 2540m wide. (One inch is 0.254m and Sketchup is based in inches.)
- Array it into 9 connected tiles so you can see what you are doing.
- Edit the center component and draw our pattern design.
- See the tiled design by toggling View > Component Edit > Hide Similar Components
- Offset it so it has line thickness.
- Erase loose edges.
- Paint the line thickness faces black (material must be based on a fully black texture)
- Paint the rest of the component’s faces white (material must be based on a fully white texture. the white face of my component was already painted before creating the component)
- Select all faces inside the component
- Right click a face and select “Combine Textures” from the context menu.
Have fun!
