Critical Issue with Revit Importer – All Instances as Unique Components
Hi everyone,
I’ve updated the Revit Importer extension to the latest version (1.2025.0312), but I’m still experiencing a major issue in both SketchUp 2024 and 2025.
When importing a project file from Revit, all instances of Revit families (doors, windows, etc.) are now recognized as unique SketchUp components. This significantly increases the file size, making it slow, heavy, and nearly impossible to work with.
I first noticed this issue after a Revit Importer update over a month ago (unfortunately, I don’t recall the exact version). Despite multiple updates and the release of SketchUp 2025, the problem persists.
Has anyone else encountered this? Any workarounds or fixes?
Thanks!
That is what happens if you export Revit to IFC or 3D DWG too. All components become unique. I would guess that this is a function of the Revit file format itself.
Before the February update, the Revit Importer extension was able to recognize Revit families as SketchUp components—mostly… because, if an object was even mirrored in Revit, it would be treated as a separate component in SketchUp.
With the February update, all objects are now recognized as unique components, making the model much bigger and harder to work with. Essentially, this makes the export/import process basically no different from using IFC or DWG formats, as you mentioned.
I have been exploding all the walls into one object, mullions into one, etc. That seems to help and make the Outliner view a bit more sane :smiley:
This is being addressed so users can choose what behaviour they want to use, an option will be added to the new UI.
To add to Tiago’s comment, this was changed in 1.2025.02.14 to improve metadata support - I’ve updated the release notes on SketchUp Extension Warehouse to try and clarify this.
Hi Tiago and Daniel,
Thank you for your prompt reply. I’m glad to hear that this issue has been addressed.
In software development, best practice should be to enhance existing functionality rather than remove it (even temporarily), as losing a critical feature can significantly disrupt professional workflows.
IMHO, I don’t see the reasoning behind making this function optional in the next UI. A key value of the Revit Importer extension—and the justification for upgrading to the Studio version—is to ensure that Revit families are recognized as true components in SketchUp rather than single-component entities.
I hope the ongoing improvements in metadata support will further enhance how SketchUp recognizes Revit families. As I previously mentioned, when the extension was functioning, even mirrored objects in Revit were treated as separate components in SketchUp.
Thank you for your attention!
Matching semantics between two different solutions is not always straightforward, as we are currently limited by the available SDKs. For now, we are required to provide a UI option to choose between a single component definition for geometry or a unique component definition for data. Let’s see how things evolve, this option may not be necessary in the future.
I get it, and I know it’s not easy working with their SDK. I’m looking forward to see how things evolve. In the meantime, is there a way to roll back to the previous version of the Revit Importer extension, at least in SketchUp 2024? Thanks.
@francesco.dambrosio You should be able to uninstall Revit Importer from the extension manager, then restart SketchUp and you will be back with the version of Revit Importer that it shipped with (2024.03.18).
We’ve tested this internally with SketchUp 2024 and it worked OK.
Dan
Thanks, Dan! It works! Once again, the ability to recognize components from Revit families is essential. I hope you can fix the new version ASAP. Thanks!
Hi everyone,
I’ve looked at this conversation with interest cause i’ve had the same problems as francesco,
I completely agree with him, the previous version was working better. If i can add another issue i’m having with this latest version is about geometry normals!
In previous version i’ve never encountered this problem but actually, many objects have normal issues and as the components are uniques, it’s a pain to change normals!
Do you have any solutions about it? someone else struggling with it?
Thanks for support,
Raffaele
Hi Raffaele,
I hadn’t noticed the normal issue, but yes, it is definitely annoying.
I’ve gone back to SketchUp 2024 with the previous Revit Importer (2024.03.18).
Hopefully, the next update will sort out all these issues. Soon.
any idea When will the issue with Revit imports be resolved? Is there an estimated timeline for a solution? The extension warehouse indicates that it is functioning properly. However, I have attempted to convert a Revit model into SKP (2024-2025), but the same problem continues to occur. I have Sketch up tudio and a Revit converter installed on my PC (version 1.2025.0312). thank you
@ddimauro_sgh An updated version was added to Labs 3 weeks ago that adds user control over this behaviour at https://labs.trimble.com/ under the " Advanced Workflow Group" project. We are planning to release that to Extension Warehouse soon as we have had no negative user feedback on there.
Thank you for answering how I can access the updated version.
Yes, it works, I can confirm that. I’m still not sure about the purpose of the Import Revit Metadata option but when disabled, the same Revit families are imported as Components (as long as the objects aren’t oriented differently).
Thank you
@tiagoricotta can explain it better than me, but my understanding is that in a BIM workflow the metadata is more useful, but for visualisation purposes it’s more useful to have the families imported as components.
The objective is for SketchUp to preserve Revit properties. Preserving Revit properties allow users to use SkerchUp as part of their BIM workflows and not only for visualization as Daniel shared. This was a top request from many different companies around the globe.
