Hey All!
I’ve been putting some thought into this but haven’t had the time to test it out yet. I wanted to get feedback from the community on the best (cleanest) way to go about this. I took a screenshot of what I’d like to achieve below: Solid lines for the proposed grade (altered 3D mesh using sandbox tools), and dashed lines for the existing grade (the un-altered 3D mesh from topo surveyors).
I plan to:
- Creating separate tags for the proposed, and existing geometry. The existing topo tag will have a dashed line type.
- Save a copy of the existing topo on each tag.
- Hide the existing topo tag geometry, and make necessary grade changes to the proposed grade geometry copy.
- After grading is finished, re-contour the proposed geometry mesh, using planes to intersect the geometry at the same interval as existing topo geometry.
- Create separate scenes isolating proposed and existing topo contours.
- Stack viewports in layout and adjust the line weights as needed.
Does this seem like a suitable method for creating the desired effect? Curious to see if anybody has tried to do this any other way, or if any handy plugins may help.
Thanks!
