Trying to copy labels from one area of a page to another, but the arrows remain pointing to the original object. I found a thread from 2021 with this same problem, but clicking on the leader instead of the label text did not solve this … I’m wondering if this is a Mac vs. PC issue?
I’m clicking on the labels leader, pressing the option key (and getting the + sign to indicate copy) and then dragging the copy to a new location … unfortunately the arrow remains attached to the old object …
What about labels in groups? Several of my scrapbook callouts are labels grouped with a symbol or other graphics, and grabbing the arrow head when it is in a group does not seem to “un-glue” it from its original location.
There are two possible solutions. First, place the group so the label’s leader anchors to the model in the viewport. Here I managed to get the leader for the scale to anchor.
This can be tricky if you have more than one label as in the example here. You can make this sort of thing easier by editing the leaders for the labels so they end at the same point.
Alternatively, you can place the group where you want it to start. Then you have to edit the group and move the ends of the leaders to anchor on the model.
Dave, that’s a great use case for the kind of label in a group that I so often want to copy, and where I want the arrowhead of the copy to not stay glued to the original geometry. The way it appears to be doing for you in your videos.
My view title is set up so that when I place it in the right place, the scale label leader will fall within the viewport above. The arrowhead has to touch actual geometry for the scale label to populate, but it anchors to its initial location even when it is in empty space. If the scale label arrowhead falls anywhere within a viewport, the scale leaders of any copies will stretch back to that original arrowhead location, and I have to manually edit each one to point to the correct viewport.
The only way I can think of to avoid that would be to place the title not where I need it to be, so that the arrowhead falls outside of any viewport. Then I would make copies, also not where I need them to be, and finally would move them all into the correct places. In most situations I do not think this workaround would save me time.
Instead of copying the first label after bringing it in from the scrapbook, just continue dropping new ones for each viewport until you have what you need.
That’s what I do when it makes sense. But it’s not uncommon that I have some project- or page-specific information that gets repeated in several view titles, and I’d prefer not to have to retype it into each view title. (Or copy-paste it, with all the clicking and double clicking involved in getting into the text box within the group and back out.)
But it sounds like the short answer to my question is, no, once a label within a group anchors to something, there’s not a way to make an un-anchored copy.
