Is it possible to copy a component from one model to another.
Yes. Select the component and hit Edit>Copy or the appropriate shortcut. Go to the other file and choose Edit>Paste (or appropriate shortcut) or Paste in place.
thanks.
Doesn’t seem to work for Sketchup Free. Nevermind, it does. Open one project, select, copy. Then go to the menu and open your other project. Then you can paste.
You can’t have both projects open in two different windows. That doesn’t seem to work.
The question was posted in the SketchUp Pro category and my answer was directed at a SketchUp Pro user. For SketchUp Free you can copy and paste between SketchUp files.
You can also save your components to your Trimble Connect storage and then import them into your other file. Or you could use the 3D Warehouse to save your components and then add them to your other files.
