Copy and mirror component
how to copy a component and step and repeat the image across an area?
Use the Move tool. Hit Ctrl to invoke the Copy function. Move the first copy the required distance and hit enter. then type xn where n is the number of copies you want. Hit Enter again.
It’s a good idea to look at the Help files, too, when you have questions. They can be enlightening. For example: Copying What You’ve Already Drawn | SketchUp Help
As for mirroring, you can use Flip Along or the Scale tool and -1 for the scale factor.
If you wanted every other one to be mirrored, you could do the first copy, flip the second version, then select both before do another move/copy. Then you could type xn as mentioned, and you would have a row of alternating components where every second one is mirrored.
appreciated
cid:afc1dc46-7f0b-4a00-b09d-85a2984967c9
Mark Minkus, President
MMI International
289 Forester Way
Park Ridge, NJ 07656
201.331.8318
201.403.8000 (Mobile)
201.331.8319 (Fax)
mailto:mminkus@mmi-int.com mminkus@mmi-int.com
Skype: markmmi
Mark, what exactly are you drawing? Perhaps with more information, I can give you more detail.
Array is the term you’re searching for…
With those contact details I think I know more about Mark than about me.
Geo, if you had sets of d, oo, ll, ho, & yw, could you make Array for Hollywood?
Rather than make something up, I’ll admit, @colin, I don’t understand your question.
It’s a rather appalling pun, Hooray for Hollywood.
Isn’t this about copying a component to fill an area rather than along one straight line or curve, i.e. like a “string” of components?
Copy the selected “string” of components in the perpendicular direction, just like you did / would do to get the string: copy once, then type 7* [Enter] to get 7+original times the selection.
As for Hoorayllywood, I wouldn’t know how to do that.
Appalling is my middle name. My parents had a strange sense of humor.
Hi! It is clear on how to copy components anywhere on the drawing or number of times to copy. Mirror is the best example I can explain but not clearly. Suppose you have a box shaped like L and how do I copy to make it look like L written backwards without use of rotate/move functions?
Are you still using SketchUp 2015 as indicated in your forum profile?
If so you can use Move/Copy and then Flip Along. If you’re using SketchUp 2023 you can use the Flip tool for that.
using SketchUp 2023 desktop
where do I find that flip function?
Please update your forum profile.
And use Flip to create the mirrored copy. Tap Ctrl before flipping to activate the Copy feature.
flip
