Conditional formula for the last copy's length of a component
Hi all,
Can someone tell me is there any way to use a conditional formula for the last copy of a component?
For an example:
if(last copy of a component’s! lenX = 5, then value, else value)
thanks in advance
the last copy would be at copy=copies, so
lenx =if (copies=copy, remainder, full distance)
If you are working on 2D array:-
based on if being true if >0 or false if<=0, can simplify if(value,1,0)
if copy to be changed at end of row, then take integer from real to see if remainder…
lenx =if((copy+1)/num in row-int((copy+1)/num in row), full length, remainder)
so say copies =5, num in rows =, remainder =7, full length =10
then if copy =0,
lenx= 1/3-int(1/3) = 0.333 -0 = 0.333, which is true, so lenx=10
for copy =1
lenx =2/3-int(2/3) = 0.667 -0 = 0.667 which is true, so lenx=10
for copy =2
lenx =3/3-int(3/3) = 1 - 1 =0 which is false, so lenx=7
4/3-1=0.333 true
5/3-1=0.667 true
6/3 -2 =0 false
and so on
Is that possible to use same like this to another component?
for an example:
if the component#1 has 5 copies.
I have to use the condition in component#2
if the component#1’s last copy’s length=5, then component#2’s length=10, else value
is this possible?
if allowed component#2 to always be last, then component#1 copies = number - 2
or a condition copies =number-if(remainder,2,1)
component#2 position would be (length of component#1)*(number - 1)
and its length =if(remainder,remainder, 10)
hidden = if(remainder,0,1)
please upload example, then can correct syntax to suit
Condition example.skp (340.5 KB)
for an example I uploaded a file here. Here,
component 1 has 5 copies. each copy is at 5cm equal spacing except last copy. last copy is 35cm.
What I want here is,
component 2’s length wants to depend on component 1’s last copies position.
if the component 1 last copy’s position =35cm , then component 2’s length = 10, 15
I understand this is a simplified version of the problem and this soloution is simple and may not required.
Condition example (1).skp (344.3 KB)
