Components Deleted
What happens to components that are deleted from an active drawing? Do they remain somewhere in a holding place? If so, can I get to them to reinsert them? If so, how?
TIA
Unless you purge unused components from the file, the components do remain in the In Model components. You can drag them out into the model space if needed. Deleted groups are gone unless you immediately hit Undo.
Thank you, Dave. That is good to know. How do I access them? Is there a menu or command sequence I need to follow?
Go to the Components panel in the tray, click on the house icon or select In Model from the drop down list. Your in model components will all be there. Select the desired component and place it in your model space.
Screenshot - 9_3_2021 , 7_27_22 PM
Thank you, Dave!!
Hello, my laptop is very sluggish. I am deleting unwanted components but when i go back to the component file they have returned !! Could someone help please …
Window → Model Info → Statistics → Purge Unused.
