Component Attribute size values are red with # in front
I created a component and when I fix the Component Size Attirbutes (with =) I get LenX value as ‘#=100 cm’ in red (except for = sign). Why? Tried searching for explanation but couldn’t find one. What have I done wrong?
try = 100
the red # indicates an error, I believe that you are tying to pass a string “100 cm” as a value.
this will also appear when a attribute value is not initialized in the option dialog.
Thanks. I think I got one for the next Doh book. Don’t type units after the value in the components attribute box. SU doesn’t like it. One of those days.
Found it: removed cm in the expression
